sleeved blocks
RE: sleeved blocks
ORIGINAL: Jasperstang308
does that mean i would be able to push the motor harder? aka block? i am wanting a solid 600rwhp out of a stock block just to prove they can be pushed further
RE: sleeved blocks
i thought it was the mains that walked? and mexican blocks have thicker mains then the avg roller block
RE: sleeved blocks
is there any other machine work i need to worry about since its sleeved? i was going to add a main girdle to help prevent man cap walk, stud the mains, deburr the block,
anything else i should do?
RE: sleeved blocks
RE: sleeved blocks
when i get the pics from the guy about the sleeves and the block itself i will post it up on here
RE: sleeved blocks
the problem with sleeving all 8 cylinders is you add the possibility of what could best be described as flexing the block when your doing that. you have a whole bank of 4 cylinders on each side that has little casting material around each sleeve to actually hold everything together, sure the sleeves are stronger - but they are press fitted together in what is now a thin "flimsy" hollow shell that used to be a bank of 4 cylinders. the huge overboring and knocking in all those sleeves just basicly swiss cheeses the block and can make things a bit unstable.
how do i know? the one ford race motor we ever built for the roundy round track was a boss 302 (a REAL 69/70 boss 302), the shop owner wanted to go big, and as such all 8 holes were sleeved and then bored to 4.125 IIRC (we even used block cement in the lower half to try and keep things stout). anyways, during the test and tune session the motor was pulling the car to some of the fastest times the local track had ever seen right from the start - until the motor decided to pull the pin and that thing grenaded all over the track. after that, i would never want a 8 sleeved block [8D] (and yeah, lot more than 300 invested for 8 sleeves, so whats the deal there)
