heating controls
heating controls
Im having a problem with my heating controls.It is stuck on defrost.Its not stuck like I can move it to any other setting like feet or whatever,but it wont change it will just stay on defrost,and even when I turn it to off it still stays on defrost.The blower level works and the heat and cold climate work fine it just always is stuck on defrost.An ideas?thanks.
RE: heating controls
check the vacuum distribution tree. where the brake booster line comes out of. if you look closely, you'll see a litte "A/C" stamped in it. if that line is disconnected it will only blow out the defroster. mine broke there. if not, check the vac lines you can get to under/ to the left of the glove box before you start taking things apart...
hope you find it.
hope you find it.
still didnt check it.I noticed my shifter was shaking just the handle so I took the boot off and saw that one of the bolts came out,so I fixed that first.Ill let you guys know though tomorrow.Friday is my day off so either thursday or friday ill try and fix it.
