Timing/water pump stud
Old 02-26-2005, 03:19 PM
tinner7
tinner7's Avatar
Default Timing/water pump stud
I started working on this 302 I have, redoing the gaskets on it, well I noticed that one of the studs that work both as the timing cover and waterpump holds, is broke, and is pretty rusted to the block for that matter. I have been thumbing threw some catalogs and I haven't been able to find a replacement one or set, anyone have a idea where I can look?
tinner7 is offline
Old 02-26-2005, 03:25 PM
Dan89lx
Dan89lx's Avatar
Default RE: Timing/water pump stud
try one of the resto places like 5.0resto i thinks its www.50resto.com if all else fails, just use a stud from the hardware store and some nuts. I have used threaded rod on my car before on my intake because the stock bolts would not work with my spacer. Good Luck
Dan89lx is offline
Old 02-26-2005, 06:14 PM
Tims 88GT
Tims 88GT's Avatar
get it from the ford dealer thats where i got mine.
Tims 88GT is offline
Old 02-26-2005, 08:13 PM
tinner7
tinner7's Avatar
well I what I feared would happen, did, the dang stud sheared off at the block, I now have to try and remeber how to use a extractor
tinner7 is offline
Old 02-26-2005, 08:15 PM
Tims 88GT
Tims 88GT's Avatar
i just drilled mine out. all of them broke[:@]
Old 02-26-2005, 08:16 PM
86HOGT
86HOGT's Avatar
sounds like fun [:'(]
86HOGT is offline
Old 02-26-2005, 08:19 PM
tinner7
tinner7's Avatar
so what do you do? I know its a 5/15 thread, I have both a extractor and a threader set, please tell me, do i just use a smaller drill bit and then use the extractor followed by the threader? its been so long since I messed with these, I hate to mess it up
tinner7 is offline
Old 02-27-2005, 12:02 AM
mustang8719
mustang8719's Avatar
If you have an extractor set it should tell you which size drill bit to use.Also make sure you drill straight and dont snap off the extractor.Then you will have to take it to a machine shop.
mustang8719 is offline
Old 02-27-2005, 12:09 AM
Tims 88GT
Tims 88GT's Avatar
Not true i say dont even play with the extractor they suck, i just used a little smaller drill bit and drilled it out but DO NOT MAKE THE WHOLE BIGGER it is ok if it is a little smaller when you thead it the rest of the bolt should crack out. also start with a small drill bit and try to make it as centered as possable on the old bolt.
ORIGINAL: mustang8719
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
Bokeo
10-10-2015 08:28 PM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Timing/water pump stud
