Great sound but....Help!
RE: Great sound but....Help!
yeah i noticed a little power lost when i put my h-pipe on but my high end was better, exhaust is a hi end part, like maf,tb, i would say now get some heads and a cam, how many miles is on your motor?
cant even peel out? you must have one serious power loss... id recheck the firing order when u changed the cap..maybe put a wire on wrong? i dont know.. i just cant see it doing THAT much of a power loss
my car wont start with the wrong fireing order correct? i tired switching it but it wont start, it started one time with 2 plug wires switched it was like the 4 abd 6 cylender wire, but it was horrible and backfiring and i had horrible milege. i drove it for only a few miles. so we switched the wires back and it finally ran good, but it seems i lost alot of low end. i have an auto trans would that make a difference?
it will still start as long as #1 is correct i beleive, just not run right.. like choppy, im assuming its runing right, you would be able to tell if a wire was wrong from how its running. im just not sure what else could be wrong...
yea im clueless, the guy said a V8 shouldnt have a problem with loosing power much with dumps,the guy across the street from me has a 1996 supercharged cobra and he has dumps....but he has tons of power so it prob actually helps him out....
You have an x or h pipe? I hear H-Pipes give you better low end and X-Pipes give you better high end. I know you said it sounds great but have you checked for leaks? My friend had an exhaust put on and they did a **** poor job. They left all kinds of leaks all over the place. It sounded awsome but he lost tons of low end. Just like you he couldn't even peal out. Once the leaks were fixed he could spin the wheels all day, but he lost some of that great sound.
