Motor did not start
Motor did not start
I tried to fire up my rebuilt 5.0 and nothing, occasionally it sounded like it wanted to fire. I tested the injector plugs with a noid light and they are getting elect., also there is spark and fuel pressure. I did rotate the distributor as far as it could rotate clockwise but still nothing. If I have the distributor in and it is off by one tooth could this cause a no start condition?
Regards!
Ed
Regards!
Ed
RE: Motor did not start
ORIGINAL: fasteddie
Regards!
Ed
Regards!
Ed
check timing, thats your problem right there.
It does sound to me like timing as well, I would also check how you routed the wires, make sure you have the right firing order. This is a cause of no start as well Hope you figure it out, I think the majority of us that have rebuilt an engine have had the SAME problem!
