Need advice for Power Steering Removal
I have a 95 GT with a 347 Stroker that I am parting out. I am keeping the engine and trans. I am trying to remove the power steering pump and manual says I need a special tool to remove/install pulley wheel on pump. Does anyone know the part numbers for these installation and removal tools, costs, and best place to purchase them?
I also see that the heads of the bolts mounting the power steering pump to the bracket look like torkx drivers. What type of socket set should I buy to remove these special bolts? Does Sears carry these drivers?
All advice and suggestions will Greatly Be Appreciated!
Dane
Dane
RE: Need advice for Power Steering Removal
sears has every thing you need the power steering bolts dont need a torx a regular socket will fit i think its a 10mm or 3/8, or this is what i used because i could not find my torx.
Auto zone or another parts store will rent the puller you nead . it grips the lip right next to the pump shaft , then uses a wrench to work it off . The new pump should come with a threaded rod that screws into the pump shaft . then slide the pullie over that and run it home with a nut and washer . If it did not come with a rod nut and washer just use one thats laying around .
Do not put the pullie on with a hammer the pump will break
Thanks Guys!
I pulled the pulley yesterday. I bought pulley puller from auto zone. I could of just borrowed one with a deposit and returned it but I decided to add a new tool to my tool box.
I also bought a metric 12 point socket set from sears. I was told you need a 12 point to get them off. Also found same syle nuts on drive shaft at rear I have to remove. Well the nuts on the power steering pump are not metric so I wasted some money. I may return them to sears. I did get a 12 point metric socket to fit on one of the drive shaft nuts. It went on with force. I don't know if those nuts are metric or not. May put a post up with that question. I took the bolt out under the pulley holding the bracket onto the engine then I re-installed the pulley so it doesn't get lost and/or the shaft doesn't get rusty. I took the braket off with the power steering pump and air conditioning condensor on it. As always I put the bolts in a zip lock bag that is labeled and squirted some wd40 in it before sealing.
Now I have a problem getting passenger side long tube header off. Looks like I have to take out the starter. I can't reach the starter and I don't know what size the bolt is. One more mystery that needs to be solved.
Thank You and Have a Great Day!
Dane
Dane
