rebuilt motor
RE: rebuilt motor
not really a rebuild just removed everything but crank to replace pistons rods seals gaskets and what not and pu he 1 rod in and torked down and know i cant move the crank with a breaker bar if all else fails i will remove bottom end and plastiaguage the rod bearins the check clearence
RE: rebuilt motor
ORIGINAL: bluepony1
Or did you take the original parts out to replace them with new pistons and rods?
How did you measure piston to wall clearance to tell if it needs an overbore?
My advice is to take all the parts to a machine shop and have them tell you what it needs, then when you get the block, crank, and rods w/ pistons pressed on back, then reassemble it with new rings and bearings.
I'm wondering how you got the pistons out in the first place without breaking the ringlands on the pistons if there was a wear ridge at the top of the cylinders? Or maybe the cylinders weren't worn?
There's a tool called a ridge reamer to cut the ridge down, but I don't think you can just re-hone the cylinders after using a ridge reamer, the block usually has to be re-bored because the wear ridge was created by the top piston ring, and if you cut deeper than the actual ridge, new rings will never seal again.
Matt's 95 Stang
10-05-2015 07:16 AM
