Heat only comes out of the defroster no matter where i turn the knob...
RE: Heat only comes out of the defroster no matter where i turn the ****...
Deff. check the vacuum lines, sounds to me like its in fail mode which always puts it up to defrost with a tiny bit out bottom. It would prob help to have a book or somthing to show where they run the lines. Good luck an LUK how it went.
This is a common problem on late model Fords, cars and trucks alike. Check your A/C temperature adjustment, if you cannot control the temperature then yes, the dash is coming apart.
so i should be able to see on the back of the controls where a line is disconnected/damaged, and if not i need to follow all the hoses?
ORIGINAL: ISwearItsStock
Yea kinda gotta do it that way ISwear unless you have a haynes/chilton or somthing that might show you in a lil more detail which lines are which...id just pull out the controler and unplug the main vacuum line connectror and see if u gots any vaccum anywhere..if not I know that the only supply line for the controls comes through the firewall right up behind the passanger strut tower, same place the heater hoses and a/c lines come through..it should go right up to the engine from there.. Let us know (LUK)
check the yellow hose that connects to the switches in the dash. also theres a vacuum line thats on the passenger side near the firewall. i believe it connects to the little vaccum lines over there, i dont remember for sure because i removed it all.
I had this exact problem too! It did turn out to be a vacum line. It was the one that came out right in front of the steering wheel when looking under the hood. There are three lines there and one of them says "A/C" above it. Thats was the one for me. Good luck!
Seanam
10-04-2015 10:15 AM
jessicarabbit
09-25-2015 12:41 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
