no you shouldn't just slap parts.....if it's running rough you could have a vaccum leak and or a misfire an egr stuck partially open would cause a rough idle but you can run a koeo/koer test to verify if the computer is picking up a problem if none are indicated by codes then check ignition components like cap rotor and wires and check for vaccum leaks also
