Battery relocation ground help
Old 10-31-2007, 03:42 AM
Ze2222
Ze2222's Avatar
Default Battery relocation ground help
I'm almost done my battery relocation. I'm just curious to where u boys grounded ur engine block to unibody upfront?
Also did u run another ground from engine block to the negative battery post?
any help would be appreicated!
Ze2222 is offline
Old 10-31-2007, 04:53 AM
92GreyGT
92GreyGT's Avatar
Default RE: Battery relocation ground help
I took my sway bar off on the front so I used the mounting pad on the drivers side to ground to the engine block to. In the rear I just made sure that I had a good clean ground through the frame rail. Mine works fine.
92GreyGT is offline
Old 10-31-2007, 06:07 AM
stang8689
stang8689's Avatar
Iran ground to the rear frame than grounded the enging to the front. I also have subframes
stang8689 is offline
Old 11-02-2007, 03:35 PM
Ze2222
Ze2222's Avatar
as for grounds in the truck, did u boys ground it to the p/s quad shock bolt... I've been lookin around and that seems like the best spot to go ?!?! where did u guys put it?
Ze2222 is offline
Old 11-02-2007, 04:27 PM
cleanfitty
cleanfitty's Avatar
ORIGINAL: stang8689
Yes, this is a must!!!
cleanfitty is offline
Old 11-02-2007, 08:01 PM
JohnnyK
JohnnyK's Avatar
Make sure you have a real good ground in the rear. I have my 67 relocated to the back, with a 1gauge going up to the solenoid, and a cable from the engine to the firewall. In the rear I have a cable from the - battery to the bumper bolt. Won't even turn the engine over.
JohnnyK is offline
Old 11-02-2007, 08:05 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Iused a longer stud on the sway bar mounting surface and double nutted it and place the grounds there
mjr46 is offline
Old 11-02-2007, 09:02 PM
cleanfitty
cleanfitty's Avatar
ORIGINAL: mjr46
I hope you then grounded out the block somwhere...
Old 11-02-2007, 09:08 PM
mjr46
mjr46's Avatar
No, I use osmosis to create the rest of the path to ground........shiz man I have so many grounds on it can't remeber all of them...one from the firewall to heads one from motor mount to frame......and the rest forgot where I put them all
mjr46 is offline
Old 11-02-2007, 09:12 PM
cleanfitty
cleanfitty's Avatar
ORIGINAL: mjr46
No, I use osmosis
Youused anOzzy album??? What, Perry Mason, See you on the other side???
Quick Reply: Battery relocation ground help
