lifter fixer stuff...
My friend told me about this stuff you buy that you put in you oil that will fix clogged or bad lifters, does anyone have experience before I try this stuff. The reason why is I have 1 lifter that is clogged with dirt or something, the lifter work then it doesnt its on and off whether it works or not. So i figure I could give it a try? should I?
RE: lifter fixer stuff...
DO NOT PUT THAT &^$@ IN YOUR CAR
You will lose evry oil seal on the whole engin. If it can break down dirt and sludg how does it know no to break down gaskets. That %$#@ should be taken off the market . Stay away thare is no easy fix . Got to take the engin out and brush out the oil passages . Get the dirt out or your just going to go througt this again.
