Tranny swap
RE: Tranny swap
Most likely not.
You might get lucky and find a complete setup on ebay though.
Im very seriously considering a 5 speed swap in my car due to the fact that I absolutely cant stand the automatic anymore. I just dont like the way it shifts even with a shift kit.
One thing Im wondering about this swap is if the crossmember needs replacing. Ive seen alot of them listed on ebay as 5 speed crossmembers but I thought all v8 ones were the same.
RE: Tranny swap
you can use the stock cross member, but you need to grind off the tack welds that keep the cross member in place at the ends... once you have the new tranny installed, you SHOULD get the crossmember welded again so it removes any excess play.
RE: Tranny swap
just bought my conversion kit from here the other day.
http://www.ampperformance.com/xcart/home.php?cat=284
Matt's 95 Stang
10-05-2015 07:16 AM
treesloth
09-28-2015 07:03 AM
