rebuild yes or no
Old 03-01-2005, 03:31 PM
link1235jeff
link1235jeff's Avatar
Default rebuild yes or no
i have 158,000 mile on all stock engine in a 1992 mustang gt 5.0 302 hatchback
should i do a rebuild it runs strong no smoke or eating oil
so should i do a engine rebuild
link1235jeff is offline
Old 03-01-2005, 03:32 PM
stanglx2002
stanglx2002's Avatar
Default RE: rebuild yes or no
you should be fine and since you dont have any problems why spend the money
stanglx2002 is offline
Old 03-01-2005, 03:42 PM
619socalstang
619socalstang's Avatar
NO, are you crazy if it AINT BROKE DONT FIX IT! unless you need to go FASTER.
619socalstang is offline
Bkizzle
Bkizzle's Avatar
Yeah i say no... if it starts giving you problems and you have the money ... go ahead but stick with it for now
Bkizzle is offline
Old 03-01-2005, 04:35 PM
mustang8719
mustang8719's Avatar
I agree leave it till it gives you problems.You probably have atleast a year or to left on that engine.
mustang8719 is offline
Old 03-01-2005, 04:36 PM
stanglx2002
put some mods on it and when it starts to give you trouble then rebuild it
Old 03-01-2005, 04:45 PM
Derf00
Gentleman's Relish
Derf00's Avatar
If you're going to be doing top end or lower end upgrades to the heart of the motor (performance cam, performance heads, balanced crank, pistons, etc) then go ahead and rebuild it as part of the first process. If you're doing mainly bolt-ons...don't do it yet., otherwise you're just doing a lot of double-work.
Derf00 is offline
Old 03-01-2005, 07:08 PM
link1235jeff
for performance cam, performance heads do i need to rebuild it cause i would like to bore it .030 over and do not what to have to buy performance cam, performance heads again cause i bored it over
Old 03-02-2005, 03:36 AM
Ezrider
Ezrider's Avatar
well if you bore the motor .030 over that is somthing that is done in the process of rebiulding and if you are going to do that and preformance heads, i would sugest a cam to take full advantage of the heads
Ezrider is offline
Old 03-02-2005, 05:34 PM
link1235jeff
do ya ll know any good kits for boreing .030 over
Quick Reply: rebuild yes or no
