Transmission
RE: Transmission
so what gear doesnt work? i forget what those parts are called, but im prty damn sure its part of a valve/w/e u wanna call it that is used to enguage/disenguage bands....
atleast, all the auto's ive taken apart... but i havent opened an aod
RE: Transmission
All the gears work. The only problem I have had with it was if I got on it, It seemed like no power was transferring. I could move faster if I kick it in to passing gear then actually getting on it. It's an aode too
RE: Transmission
well by what gear , i meant what was either slipping or just straight up not enguaging... u said no power in od? that would make sense, as its common for o/d to be held by a band... let an auto guy get in here and tell you whats up. im more of a manual guy, but ive done a few turbo350s, hydramatics, and 700r4s... no ford trannys tho... (by done i mean compleetly dissasembled and back together)
if i had the trans in front of me id be able to help u more... i have an aod at home, but, they may be differant enough for it to not show me anything...
RE: Transmission
this is one of the valves obviously in the valve body which controls hydrsulic pressure/fluid flow to one of the gears..........you'll have to look up in the valve body and see where it used to be[&:]
RE: Transmission
the retaining clip broke, -common.
Drop the valve body, might as well do the J-MOD and purchase another retainer through Ford, . Ask their transmission technician and show him the pieces and valve body if you dont know what part you need.
or
here is one on ebay for $30 good shape, decent guy
http://cgi.ebay.com/ebaymotors/AODE-...spagenameZWD1V
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
[align=center] [/align]
or
