highbeams HELP!!
highbeams HELP!!
Ok well all my lights work, parking and driving lights or w/e. But when i push the lever out for the HB's the lights shut off, but if i pull the lever towards me and hold it, they work, TELL ME WHATS WRONG PLEASE!! its driving me nuts
RE: highbeams HELP!!
thats kinda odd, your bulbs still are fine becasue if u hold it back they r on..hmm...is there a fude for them maybe? sounds like that could be the porblem! not sure man, confusing one. hope someone here has the answer for ya
When you Push the high Beams there saposed to stay on Hi beams , and when you pull them there a little brighter but they obviously wont stay .. you must have a wire somewhere wired wrong with your lgihts thats the only thing it can be
Sounds like a short in the multi-function switch. If it pulls too much current, it'll kick the breaker which will self-reset later. Or if it's bad it may break the circuit shut the lights off and pull zero curent.
Hey my car Does the exact same thing. When you push the stick foward to keep the HB's on it shuts off all the lights, But when you pull it back the brights come on.I have the same problem But it drives me nuts also, I just dont use my Brights until I really need to, then I just hold the handle back.
yea same, im just gonna use my driving and fog lights, it looks cool anyway, since there the yellow fogs and smoke headlights, nowhere around here reall requires BH's, cept my own street of course cuz we have no street lights, but i know the street and my other lights will be fine, so screw it
I have a problem with my fog lights, when I turn them on, they (and all the other lights) stay on, but after a while, they will all go off (except lights inside). Then after 5-25 sec, they come on again. There is no large bump or anything like that I go over when this happens. Needless to say I don't use my fogs much/ever. Anyclue...fuse?
sounds like the circuit breaker is tripping and then resetting itself after a few seconds. you need to check the wiring for a frayed wire or something else causing a short circuit which is tripping the circuit breaker.
ORIGINAL: bmorrisj
its either time for a new multifunction switch, as one of the pins and whatever connected to it could be burnt, or the harness is melted....or both...
if connectors look ok and pins arent burnt or anything it sounds like multi function switch itself.
