fuse location question......
i was messing around with my ac/heater fan wiring in my wifes 1985 mustang GT and shorted a hot wire to the firewall by acident ( i know should have pulled the battery.) now my dome light is cold, the radio is cold, and the "Hot" wire that i acidently shorted is no longer hot. I checked the fuse pannel under the stearing colum, the one thats under a access panel, and there is no blown fuses from what i can tell. i looked a bit and i cant for the life of me find any other fuse boxes that would contain the fuse that i poped. there are some larger fuses in the fuse panel under the stearing colum that are metal and you cant see inside of them to see if there blown, could it be one of them? any help apriciated, thank you.
RE: fuse location question......
Look harder!!!! the blower motor fuse I believe is either a 20 amp yellow one or a 30 amp green one...that is the only fuse box on 85 gt's apart from inline fusible links but those are mainly for the ignition switch and other things..........either pull the individual fuses and look at them or switch the ignition on and touch each side of the top of the fuse with a test light checking for current
man, i pulled every fuse yesterday and today, NONE of them are blown, melted, discolored, mamed, or damaged. I have no clue as to where this flipping fuse is.... Guess i will look again tomorrow, being the half blind monkey iam i probrably missed it.
thanks for the thought, i will look again tomorrow. you wouldnt happen to know the answer to this question would you? https://mustangforums.com/m_4128282/tm.htm
jwog666
12-27-2021 08:09 PM
