Fuel Pressure
Fuel Pressure
Ok i have heard that carbed cars do not require the same pressure that EFI cars do. Most of the folks that have similar set-ups but Fuelie use 255lph pumps. what is the equivalent for carbed cars. Also what is that application of the pressure regulator with a carbed set up.
RE: Fuel Pressure
holley blue pump is an equivallant performance pump that puts out 14 psi and comes with a regulator so you can dial it down to 4-6 psi where most carbed cars need to be...I have the blue pump ..it's noisy but so is my carand I run NOS so I need the extra fuel pressure capability
RE: Fuel Pressure
So you just bump the pressure prior to the run? Can it be done remotely.You may know this...will an MSD 6AL retard timing electronically for juice or does that have to be specifically dont at the Dist!!
RE: Fuel Pressure
ORIGINAL: hillbilly pony
You'll need a timing retard box for thatorI think maybe a MSDDigital 6 has a single timing retard for nitrous....
RE: Fuel Pressure
PS, the holley blue pump is commonly referred to as the "annual pump" as in it lasts about a year
RE: Fuel Pressure
ORIGINAL: 95vertGTS
You just hook up a retard box to your 6AL I'm pretty sure.
RE: Fuel Pressure
Does the return line basically branch from the input of the carb and just allow a set lower pressure to enter or is it attached somewhere else and has nothing to do with input pressure?
RE: Fuel Pressure
mrappe
09-26-2015 10:16 AM
