302 qustion
Old 11-07-2007, 11:31 AM
bignickwaite
bignickwaite's Avatar
Default 302 qustion
i have a 302 came out of a lincon mark 7 or somthing now i dont know what year but how do i know if its a roller motor or not i think it was carbed . looks like it anyways . if is not a roller motor is it worth it to fix up?
bignickwaite is offline
Old 11-07-2007, 01:19 PM
bignickwaite
Default RE: 302 qustion
nobody knows hmmmmm
Old 11-07-2007, 06:06 PM
LA95GT
LA95GT's Avatar
you dont know if the motor is carbed or not??
LA95GT is offline
Old 11-07-2007, 06:45 PM
greenstreak9205
greenstreak9205's Avatar
if its a roller motor it will have a machined surface between the lifter bores
greenstreak9205 is offline
Old 11-08-2007, 02:46 AM
joey011582
joey011582's Avatar
if it is still together andhas EFI setup on it and the intake has H.O. on it, its a roller motor. All high outputs are rollers.
joey011582 is offline
Old 11-08-2007, 02:49 AM
greenstreak9205
yea except he doesn't even kno if it was carbed....possibly its just a short block?
Old 11-08-2007, 02:55 AM
MadMan@TheWheel
MadMan@TheWheel's Avatar
The 85 Mustang GT was carbe'd and it was a roller motor...So I am not sure if that was the point, but even if it was carb'ed it could still very well be a roller motor. I'm betting that it is. If he does not know if it was acarb motor that at the very least say's A. It has no intake B. He has no idea what he is looking at...lol
MadMan@TheWheel is offline
Old 11-08-2007, 03:04 AM
joey011582
joey011582's Avatar
lol, hmmm check cast numbers on block? I was told that non roller blocks are stronger and that the roller doesn't make that much difference. Also too it should be able to rev higher without floating the valves due to the fact that flat tapets are lighter.
Old 11-08-2007, 03:23 AM
MadMan@TheWheel
ORIGINAL: joey011582
Checking numbers on blocks is common. I don't think the topic is about the pro and con of roller non-roller blocks rather if this guy's block is a roller. Flat tappet over roller is a whole other discussion, no need in getting into that in this thread. If the man wants to know if his block is roller he can:
Check and match casting numbers, look for the designee H.O. stamp that should be on it. Or tear it down and look for the obvious. It's not rocket science.
Old 11-16-2007, 08:44 AM
joey011582
joey011582's Avatar
just saying that hey its not the end of the world if it isn't, geese some people are cry babies.
Quick Reply: 302 qustion
