stock rocker question
ok so i ground down the stock rockers for clearance. went pretty smooth. and it looks like it willdo just fine.i used my bench grinder for this job which went well. do you thin it would be needed to buff that rockers where i grinded? do i need to coat them with ceramic paint? ford didnt say anything about buffing or painting them, i just want to make sure that i dont get metal shavings in my valve train.
also can someone post the site or thread about setting the rockers. how to rotate to proper position, what to torque down to, that kind of stuff.i cant find it, i forget what thread it was on. i should be able to set them and maybe start the stang up for the first time in about 4 months.
RE: stock rocker question
ORIGINAL: AdderMk2
run them over a wire wheel to remove any debris, and no, you do not need to paint them. They are going to get covered in oil anyway
ORIGINAL: dimebag
stock rockers? you grinded them down for clearnace for what???and if their STOCK, you just tq them down... unless were talking about stock cobra rockers
and i know your going to ask or wondering why im using these or why i upgraded the springs on stock heads, well just like you....im short on money for my project. i've had some tough financial battles lately and i just need to get her going. its my DD now. i got rid of my truck to my parents.so im waiting till spring to save money and get my tax return, get aftermarket heads, stud mount, and roller rockers. then im going to use your suspension set up because its cheapest ive seen that works extremely well.
i wasnt saying what u were doing was stupid... i was just curious as to why... i see now
so... your springs youve installed i assume ahve a larger diameter? that makes it all make sense now
dont think i was questioning you, i was just wondering why u were doing what u were doing... i see now.
and... your still just going to be able to tq the rockers down.. unless u shim them and ****...
so... seeing that it is a wider spring, is there any issue with the spring fitting in the seat?
and hey, thx for the suspension complaments this entire car... is a budget build, lol... u shoud see the small *** amount of money ill have in it by the end of the month... shooting for low 12s
ORIGINAL: dimebag
and yea i was really impressed with your price tag on your suspension set up. so i think i might hit that route once i get the cash flow again. the only thing then....i know the T-5 will break after the suspension is built, its already grinding if i shift quickly into second. so ill baby it for a while. i think i might hit up the TKO 500 package for the $1500 thats advertised(tranny, bell housing, cross member, shifter base)
