HOw long could you?
HOw long could you?
I have a 331 strocker chp block n if beein leting it set 4 over 4 months now i believe . I just want to know how long do I have before it starts to seize up . It was used when i bought itn it had know oil in it. it was drained out. Bout a month I sprayed it with sum oil . Its alsoraped up with plastic at my 1 of my patna house. The reason 4 it sitting i had to start to get the parts for it.
RE: HOw long could you?
When I store an engine block, I make sure that I turn it over a couple times a month to keep it oil'd properly. Just get a wrench on it and turn it over. As long as you kept it oiled and covered, you should be okay.
I would think that as long as you aren't in a super wet climate, spray a little lube in the plug holes every once in a while and keep plugs installed. you shouldn't have any trouble keeping it from seizing. if possible i wouldkeep oil in pan, take distributor out and manually spin oil pump with drill to keep oil throughout the motor. and if you are able to do that, why not manually turn crank every once in a while to keep movement. no sense letting a motor like that go bad...
lincolnshibuya
12-08-2015 04:37 PM
10-05-2015 07:40 AM
