86 5.0 - No spark..no reason
RE: 86 5.0 - No spark..no reason
ORIGINAL: Joel5.0
The box is an add-on....... you could bypass it, remove it, and check if the no spark problem is present with the stock TFI setup.
That's the next step for diagnosing this problem
ORIGINAL: jmtertz
The box is an add on? I guess I'm confused on how this ignition system is set up.
Thanks Joel, that makes sense. I figured this was a part of a stand alone ignition system. That explains the OEM distributor and how it functions. I'll remove the box and see what happens. Thanks for the help.
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
