mustang dies at startup
Old 11-09-2007, 01:01 PM
89TripleWhite
89TripleWhite's Avatar
Default mustang dies at startup
89 mustang gt conv. specs are below. in the morning, every single morning i start up the car and it idles real struggle like, and actually turns off. for example the car starts, idles up a little then bog bog, then the car boggs out, all within about 2 seconds, only does it then. if i give it some gas as its struggling then it still struggles for a secondand doesnt turn off that way (but my radio setting are reset on my headunit, as if it kills the battery for a split second....thats how the setting get reset usually)......then its ok the entire day, i can turn it off and on no problem, its only that initial startup in the morning that makes it bog out and die a couple seconds...what could it be? i just got my injectors cleaned and fuel filter changed and it has been doing it before i got that done, but its like it does it worse a little at a time, i mean its in order, 3 months ago it barely dropped under idle RPM, 2 months ago it was almost bogging out, now it is. battery maybe? alternator? i got the car used about 11 months ago and same battery, its a good battery, no clueon the alternator...but my batterychargeIS a little low........so any help would be great, thanks
89TripleWhite is offline
Old 11-09-2007, 01:21 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: mustang dies at startup
check all ground connections and terminal connections for looseness and or corrosion...also have a battery load test performed along with an alternator test to eliminate the elec system
mjr46 is offline
Old 11-09-2007, 01:24 PM
Bullitt94
Bullitt94's Avatar
Clean your battery terminals and the wire clamps really well and try it again.
Bullitt94 is offline
Old 11-09-2007, 03:06 PM
89TripleWhite
hmm yah thats kind of what im getting, so if i clean the battery cables and say dsisconnect over night for 8 hours and it relearns idle, that should take care of it? im afraid of what it will be if that doesnt work
djbigskrilla
09-20-2022 01:04 AM
MEISTERSNFB
03-31-2020 07:50 AM
NorthAmericanTuning
03-18-2016 11:21 AM
Philhampton1
08-21-2015 12:04 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: mustang dies at startup
