one thing after another
RE: one thing after another
Well here's what I went through. my car ran graet, the fuel pump worked fine when the car was running but it would loose fuel pressure immidiately when the key was turned off. If before starting the car, i turned the key on and off multiple times to build the fuel pressure back up (u can hear the pump change pitch) and then started it it would start right up, if i just turned the key to start it the car would crank a hell of a long time before finally starting, sometimes it would barely stumble to life. I figured I didn't have a leaky injector and i replaced the fuel pressure regulator so the fuel pump was the only other thing i could think of, I assume the fuel pump has a valve built into it that was stuck open or something on mine, I really dont know. But now when I shut the car off it holds fuel pressure for quite a while.
ORIGINAL: 95stang50
yeah i hooked it up to a snap on code checker....and i did a key on engine off test and it came up no codes....i wasnt able to do the key on engine on test because my car wouldnt stay running
OnyxCobra.
i kinda have the same thing going on but my car even when i was drivin it back to the school felt like it wanted to die i had to keep the gas floored just to make it back to the school....and floored wasnt going very fast
Flood mode start is the way most FI systems deal with a engine flooded condition, if you hold the gas pedal all the way down, the system shuts off injectors pulse to prevent more flooding.
No codes.... or code 111 (system pass) twice?...... did you check the injectors pulse with a noid light?
i duno what a noid light is.....and come to think of it the 111 thing looks really familar..thing is im goin back to school on monday to figure it out....its in the shop right now so i cant go work on it...
ORIGINAL: 95stang50
OnyxCobra.
OnyxCobra.
the chip is good....and yeah im pretty sure the fuel pump is good i duno man im confused out of my mind and im running out of funds....i really need to get my car running again because its my dd
ORIGINAL: 95stang50
okay so how do you fix the flooding problem? if that might be...because im gonna try everything
Do suggest to confirm the code 111, the "no codes" or not able to retrieve codes from the system, is a problem that will cause a no start as well, you may want ot check its description at www.fordfuelinjection.com ยป No Codes?
