oil leak at distributor
RE: oil leak at distributor
ok i was looking online at advance auto parts and found an 'oil felt plug' and also a part called distributor seal that linked to the same part called 'oil felt plug'. what the heck is the oil felt plug? if it's an o-ring i can just go find one the same size, they're easy to get. but if it's this oil felt plug i'll go ahead and order that.
It's just an O-ring, you should be able to remove it, take it into parts place and have them compare to get you a new one.
FYI, before you remove distributor, be sure to mark the position of the rotor inside the distributor with a sharpie marker. this will help you when reinstalling from not having to find TDC on compression stroke and restab distributor.
i cleaned it up real well then ran it and watched to see where the oil was coming from. it's a slow leak; took around a week before the oil started to run out from the bottom of distributor. i don't know what that felt plug is, but it is not an o-ring. i'll take it (the o-ring) out and just go to auto parts store and buy a new one by comparing it to the old one.
ORIGINAL: MadMan@TheWheel
There should be a small gasket.
the distributor has an O-ring. Mine was so dried up that it felt like plastic. I broke it off and popped a new one on.
bradleyb
11-27-2015 07:50 PM
