Bellhousing alignment?
Old 11-10-2007, 10:54 PM
mustangmdr
mustangmdr's Avatar
Default Bellhousing alignment?
I have never aligneda bellhousing but I just heard that it should be done.Why would I need to check alignment if im just replacing my clutch.I was also told I need to check the runout as well.If the bolts and dowels are lined up and torqued properly why would alighnment and runout need to be checked?THANKS
mustangmdr is offline
Old 11-10-2007, 11:10 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Default RE: Bellhousing alignment?
I think you only have to do that with an aftermarket peice.
Boss_Hotrod is offline
Old 11-10-2007, 11:38 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
There is a whole write up about that in the ford racing catalog and about using a dial indicator to check it...but honestly unless you had a wierd issue with clutch bellhousing issues and or a problem installing the tranny due to a misaligned bellhousing or warped part of some sort... then it's really not neccessary when replacing a clutch...if your clutch is just worn out replace it and bolt everything back together and you'll be fine.....there really is no way to align the stock bellhousing without performing mods to it
mjr46 is offline
Old 11-10-2007, 11:44 PM
mustangmdr
mustangmdr's Avatar
Thanks thats what I figured.I have always done my own clutches and never done the alignment and have never had any problems.
Old 11-11-2007, 12:39 PM
95stang50
95stang50's Avatar
the way i was taught that if the dowl pins line up and you have the right bellhousing bolts (because my friend thought he had the right bolts turned out to be to long made a gap between engine and bellhousing ruined his clutch with oil and dirt ect..)
95stang50 is offline
Old 11-13-2007, 06:44 PM
Jfsram
Jfsram's Avatar
If the bellhousing is out, aligning it is pretty easy. You replace the dowels with offset dowels.
I've checkeda few engines before. Fords, GM, Mopars. I've never seen out far enough to require correction.
This is one of those things best off left to people who worry themselves to death about everything.
Jfsram is offline
winner99
09-30-2015 07:04 PM
UrS4
09-30-2015 10:13 AM
Drastang
09-29-2015 03:31 PM
marc954
09-29-2015 11:18 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Bellhousing alignment?
