no power to coil
no power to coil
I was having a problem with my fuel pump not turning on....so i went through and tested the ccrm, pcm, fuses, wiring and came up with nothing wrong....so today i found out that there was no spark....the reason for that is there is no power going to the coil.....and if i jump a wire from the battery to the wire going to the coil the fuel pump will turn on and the coil will get power...the car will run when i jump this wire
so what would control the power going to the coil....or where does that wire come from??
RE: no power to coil
fuses are good....the ignition switch seems ok....it has always been able to turn on with out the key since i have owned it
the car just died all of asudden when this problem happened
ok i'll try checking some of the wiring again....i checked pin 22 from the pcm to pin 11and that had the right resistance .72 ...and from the fuse box to the ccrm was making the test light come on
the i/p is the unde dash fuse box right? they were all good including the number 18
also if it was the ignition switch would the relays be able to click on when i turn the switch...sounds like the absand another one...there is2 clicksclose togther when i turn the key...
there is no power getting to the coil or the fuel pump...so when i hot wire the plug in into the coil they both work
ok i will try getting that tested....or can i just test it with my ohm meter? know what the resistances are supposed to be
ORIGINAL: m_ross05
