spun a bearing?
RE: spun a bearing?
i spun em alll, A/C made a little metal on metal grinding which is prob the culprit cuase thats what hte sound is...
alt wobbled a lil bit
p/s was def not as easy to turn as the a/c and alt but it turned
water pump seemed pretty free moving and obviously i really can't turn the crank..... ill find out once i delete the a/c and put hte new pulleys on....
RE: spun a bearing?
well its not a rattling noise...
my exhaust does rattle thought, i prob have to go under here and tightend everything up
sounds kinda like a industrial strength circular saw cutting through thick metal tube, like that metal on metal contact grinding noise. pretty sure i have found the culprit its only a matter of time before i eliminate the a/c completley and put new aluminum pulleys on...
btw little off topic from this topic
with in 1 1 1/2 weeks of each other i plan on getting electric fan installed... a/c delete, p/s relocated and aluminum pulleys and obv with a/c gone a shorter belt, the car should feel alot more powerful right? then hopefully 3.90 rearend going in about a month
