spun a bearing?
spun a bearing?
Okay i developed this issue back in the middle of the summer after i just just did a delete of my smog pump and put a short belt on the car
when i rev over a certain rpm about 2500ish the car will make a metal on metal grinding noise
like a whistle but it sounds like pure metal on metal
someone said check the belt but u can't hear it under the hood only when the hood is close or ur in the car revving... from 2500rpms its consistant
doesn't seem to hurt performance...
and i was thinking it and my cousin just suggested it, i could have spun a bearing but wouldn't that make the car pretty much undriveable??
any one have similiar issue? bearing a easy fix or does the engine need to be torn into for the fix?
RE: spun a bearing?
!. if it was a main bearing or rod bearing, I would think you would be walking right about now.
2. If by chance it is either....I have not yet developed a way to replace a rod or main bearing without tearing the motor down.
If oyu have all your accessories, it coud be a bad alternator, a/c compressor, or a variety of rotating equipment issues.
RE: spun a bearing?
ORIGINAL: Alero99
still have the A/C, its coming off as soon as i can get somone to evacuate the system, hopefully thats the problem cuase i know that hte a/c clutch does no spin at all
RE: spun a bearing?
ORIGINAL: Alero99
RE: spun a bearing?
the smog pump was disconnected by the dude when he did my exhaust he welded that metal pipe thingy shut and disconnected everything fine... when i took the pump out i left the bolt that holds teh bracket in the block cause i didn't wanna leave it out... ill find out when i remove the a/c and put new pulleys on
