where can i get my block sleeved?
planning on going high boost, i dont know much about domestics, i dont even know if you have to sleeve them, but if you do, what are some good links or places in cali where i can get it done or ship it to? anybody know how thick the cylinder walls are?
RE: where can i get my block sleeved?
are you doing this to a stock block? if so dont waste them money. to properly sleeve it will cost at least 700
spend that money towards an aftermarket block such as the new boss block, a dart or man o war block and boost the hell out of it without fear of it splitting
thats still cheaper than a new block though, i still need to spend money on valvetrain, rods, pistons, bearings, crank, etc.
wouldnt it be stronger if i just sleeved this?
ORIGINAL: borisdookie7
damn, have 5.0 blocks been known to fail often? i mean i want to go for 500-800whp, but if i have to then i guess i will get a new block
400-425 flywheel HP on my 302 which was an early (stronger) block, and i snapped the crank in 10 pieces and destroyed the block......... you want an aftermarket 302 block or preferably a 351 platform to build off of. (as said already above)
ooo alright thanks guys, idk about a 351, its not wider right? just taller deck height? are the cylinder walls thinner? whats some good places to get a 351 motor for cheap? can you swap 302s and 351 and they will hook up? like tranny, mounts, with no modifications? sorry for all the questions, and thanks again for all the help
