Lightened flywheel?????
This is my first building of a high HP gas engine (I work on big rigs for a living) and keep hearing different stories from people I know about this. I'm hoping that I can get some good info from here.
I've read a couple of posts on this subject, but I can't seem to find anything that will help me. I've got an '89 5.0 HO that I am building up to swap into a Ford Ranger. On paper, I'm figuring I should have around 400HP with the mods I have done. My questionsare: Would I benefit from a lightened flywheel with this build? If so, how much lighter should I go? If I change the flywheel, do I need to change the harmonic balancer, too?
When I get my truck built, it won't be strictly a racer. I plan to drive it on the streets and occassionally take it to the track to see how it does.
Thanks for any advice I can get
RE: Lightened flywheel?????
no you do not need a lightened flywheel, but it is a good idea to get a new harmonic balancer, there cheap and if yours is stock it probably neeeds replaced. What are your mods because its pretty hard to get up to 400hp without nitrous/turbo/supercharger so id like to hear whats up.
its not really that hard to get to 400 hp without a power adder with an hci swap especially if its stroked. 331 with afr 185's r-series intake and custom cam will already be at over 400 to the wheels.
There are advantages to either set up. You have to decide what you need more.
Heavy is a smoother idle. It will be easier to take off from a dead stop in normal driving because the rpms will want to stay up as you introduce a load to the engine. If you have a drag type set up, suspension, tires etc. You can launch from a high rpm and let the flywheel inertia help you launch.
Advantange of a light flywheel. It allows the engine to rev up a slight bit quicker.
IMHO. Light flywheels for low torque, front wheel drive cars.
