Changing timing and water pump gaskets
Need of your experiences.[/align][/align]My Mustang needs the following work done:[/align][/align]1. Water pump gasket and maybe water pump[/align]2. Crank Seal[/align]3. Timing cover gasket[/align][/align]While you were doing this is there anything elseworth doing. ie. Underdrive Pullies?[/align][/align]Thanks,[/align][/align]
RE: Changing timing and water pump gaskets
on the passenger side of the block, you will see a plug with a hex hole in it remove it with an allen wrench. This is a core drain plug.
The reason you want to drain this is because coolant flows through the timing cover, and removing the timing cover without fully draining the engine, can result in coolant ending up in the oil pan.
other than that its pretty straight forward... you will have to remove the first 4 bolts on the oil pan, on each side... just to get it down enough to get the timing cover off.
FYI, goodluck with that block drain plug. chances are its rusted from the inside and i'd be willing to be you'll strip the allen socket in the plug as soon as you try to remove it. regardless of how it goes, change the oil when your done cause you never know whats going to fall down into the oil pan while your scraping old gaskets off and such.
oh yeah, and if you water pump *gasket* is leaking, you'd be a fool to not change the pump itself while it was off (they arent an expensive item)
ORIGINAL: my77stang
maybe my old engine was weird
yeah thats pretty strange indeed adder because i know from experience dealing with literally thousands of blocks and heads that hex headed plugs into water will strip very easy. the only way we could get them out on the first try was to heat the plug up red hot, then put some wax or other lube on it and loosen that bugger up while its still smoking. that method will work virtually every time.
and yeah balancers are usually stuck like chuck [&:]
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
DrunknRuckus
08-23-2015 10:05 AM
jpplaw
08-22-2015 09:29 PM
