biggest tire on 9" rims
#34
RE: biggest tire on 9" rims
sorry i just read it from this article https://mustangforums.com/m_3895037/tm.htm. they could be wrong
#35
ORIGINAL: rust_stang
Ya, ok.[sm=bangbang.gif]
These cars look pretty stupid I bet huh? All with 8" rims on 275's
ORIGINAL: Curlytop
its not the fact if they will fit. its not the proper size for that rim. plus the sh^t looks stupit. haven't you ever seen someone with the wrong size tire on the wrong size rim. either they will have the rim to big for the tire or the tire to big for the rim.
rule of thumb! they have half size that fit more exact for those smart azz.
245's on a 8' rim
275's on a 9' rim
295's on a 10' rim
315's on a 11' rim
245's on a 8' rim
275's on a 9' rim
295's on a 10' rim
315's on a 11' rim
I don't see a problem. Let's see your car!!!!
#36
hey you can suck my ****in dick addermk2. i never said i would put a 315 on a 9" wheel unless it was a nitto, even still i would still rather go with a 275 or 285. no doubt it will definatly work. will it look good? probably ****ing not, but i guess that just my opinion
#38
Mickey Thompson Drag radials(if you want traction and have to have a 315). approved rim size is 8.5 to 11.0 rim...I personally wouldn't use anything smaller than a 10 inch rim....
Part #
Size
Size
Equivalent
Appx.
Weight
Compound
Approved
Rims
Measuring
Rim
Sidewall
Width
Tread
Width
Overall
Diameter
Circ.
3752R
P235/60R15
26 X 9.50R15
27
R2
6.5-8.5
7.0
9.5
8.4
26.1
82
3753R
P275/50R15
26 X 11.50R15
31
R2
7.5-9.5
8.5
11.3
10.4
26.1
82
3756R
P255/60R15
27 X 10.50R15
31
R2
7.0-9.0
8.0
10.7
8.8
27.1
85
3754R
P275/60R15
28 X 11.50R15
33
R2
7.5-9.5
8.0
11.0
9.5
28.0
87
3757R
P325/50R15
28 X 13.50R15
37
R2
9.0-12.0
10.0
13.1
11.6
28.0
87
3762R
P295/65R15
30 X 12.50R15
38
R2
8.0-10.0
8.5
11.9
10.9
30.0
94
3763R
P315/60R15
30 X 13.50R15
39
R2
8.5-11.0
9.5
12.9
11.9
30.0
94
3793R
P255/50R16
26 X 10.50R16
29
R2
7.0-9.0
8.0
10.5
9.6
26.1
82
3743R
P275/40R17
26 X 11.50R17
28
R2
9.0-11.0
9.0
11.0
10.0
26.0
82
Part #
Size
Size
Equivalent
Appx.
Weight
Compound
Approved
Rims
Measuring
Rim
Sidewall
Width
Tread
Width
Overall
Diameter
Circ.
3752R
P235/60R15
26 X 9.50R15
27
R2
6.5-8.5
7.0
9.5
8.4
26.1
82
3753R
P275/50R15
26 X 11.50R15
31
R2
7.5-9.5
8.5
11.3
10.4
26.1
82
3756R
P255/60R15
27 X 10.50R15
31
R2
7.0-9.0
8.0
10.7
8.8
27.1
85
3754R
P275/60R15
28 X 11.50R15
33
R2
7.5-9.5
8.0
11.0
9.5
28.0
87
3757R
P325/50R15
28 X 13.50R15
37
R2
9.0-12.0
10.0
13.1
11.6
28.0
87
3762R
P295/65R15
30 X 12.50R15
38
R2
8.0-10.0
8.5
11.9
10.9
30.0
94
3763R
P315/60R15
30 X 13.50R15
39
R2
8.5-11.0
9.5
12.9
11.9
30.0
94
3793R
P255/50R16
26 X 10.50R16
29
R2
7.0-9.0
8.0
10.5
9.6
26.1
82
3743R
P275/40R17
26 X 11.50R17
28
R2
9.0-11.0
9.0
11.0
10.0
26.0
82
#39
i'vework at a tire shop for a couple of years in the late 80's. i saw different combo's all day long. the problemi would see all the time ispeople wanting to go bigger on the same size rim. a 275is meant to goon a9' rim. it can go on a 8' rim, but the 8' rim doesn'tpull the tire out all the way. you tend to havethe tire plucking out far pass the rim and sitting up tall. meaning it doesn't fully stretch out across the rim. plus, i've seen it the other way 245 on a 9' rim. the tire is being overly stretch and the rim is sticken out further than the tire. did i said you couldn't do it no. this is just the correct way of doing your sh^t right. if your happy with it keep that way.
#40
ORIGINAL: rio95cobra
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
