flywheel
RE: flywheel
yes but if it doesn't come with the dowl kit then you need to order the ford racing one that comes with new pressure plate bolts and dowls.....keep in mind that an 85 had a 10 inch clutch and that flywheel is for 86 and up and is for a 10.5 clutch...it'll work just fine as long as you don't try and use a 85 clutch with it.......so you'll need to order a clutch for a 86 and up mustang
RE: flywheel
ORIGINAL: toofst4u666
are you sure its 10 in a few other people told me it was 10.5
I just looked at my original 85 flywheel and the only real difference from my 86 and up flywheels are that it didn't come with dowl pins so the flywheel you want to buy from summit should work with either clutch as long as bolt patterns line up but If I were you I'd go 10.5 clutch and with that you'd need to install a dowl kit like I stated...but 85's are equiped with 10 inch clutches
RE: flywheel
ORIGINAL: mjr46
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
