Rear End Drum Brake Swap Question
Okay i got a new rearend sitting in my yard, i wanna put it on to replace my piece of **** 2.73 one wheeler rear end...
I need to know if there is any way to take the Drum off completely with out taking it apart and just throw it onto the new rear. then do teh swap
RE: Rear End Drum Brake Swap Question
What rear end do you have sitting there to replace the one in the car? and I think is impossible to take the whole drum off whithout moving anything unless you get in behind the axle flange there should be 4 bolts holding the rear plate of the drum on that might work but the pads and such would move i would think
let me know
let me know
What brakes does the new rear have on it now? If your talking about pulling the whole backing plate off an swapping it you are going to have to pull the axle shafts out to do that. If both are Mustang 9" drums then why not just swap out the brake shoes and drums from your old rear on to the new one if your wanting to use your old brakes.
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
