Tranny Crossmember
Tranny Crossmember
Hey everyone I am doing a t-5 swap in a 95 but im using a 90 fox t-5, I am just using a fox bellhousing because it bolts right up, but what I dont know is what crossmember to use, the fox or the 95. Im going to the junk yard tom to get some parts. Thanks~
RE: Tranny Crossmember
you can use either bellhousing. and the mount should line up perfectly.
the tranny mount is different between the fox and SN-95.. so as long as you are using a fox mount, you will be fine.
but your probably gonna punch your radio a few times when you shift into 3rd gear
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
