distributor
distributor
so today io notice that my distributor was loose so i turned it counterclockwise because it seemed harder to turn but then the car would not start, so i turned it clockwise a little to see if that was why it didnt start, and it started but runs ****ty sop i turned it clockwise alot and it seems better but isnt running all that great is the disributor sopposed to be turned al the way clockwise? i turned it til the clip is hitting a radiator hose but it seems loose still
RE: distributor
joel...i doubt he gets what ur sayin
the dist. isnt "screwed" in or anything... your going to need a timing light, and gonna have to learn how to use it(we have a write up in the stickies) set timing(10deg. btc) and tighten the bolt at the bottom of the dist. not the dist it self
RE: distributor
What the hell??? Were you thinking that the distributor is like a screw and if you turned it that it would tighten? Even if that was the case it would be lefty lucy, righty tighty. Find someone to give you a hand. A manual will be your friend.
