Fox Headers on a SN-95
I have read several threads on using fox headers on a sn-95. from what i can tell the differences are the EGR tube and the fox headers sometimes don't clear the shift fork. I have a 94 cobra with a tremec 3550. I was thinking the shoft fork would ahve been changed with the tranny swap and woudl. clear the fox headers. Is this right? Can i use fox headers or should I continue to look for a set made for my car?
RE: Fox Headers on a SN-95
Im running a 94 cobra as well, but I still have my stock T5. I also have a set of fox long tube headers on my car and so far, everything clears just fine. I'm about to put my H pipe up in place in a few. I'll get some pics up and let you know what I run into
ORIGINAL: jeffro22
was it hard to install those headers?
I could have slid them in place before I put my motor is, which would have made life easy.. but I am seeing what it takes to get them in place with the engine in.
I do things like this so I can get experience for what works good, and what doesnt.
BTW, so far, there is TONS of clearance for the clutch fork
ORIGINAL: 91hatchgt
You didn't drop the headers in bolted to the engine?
I also did not know if they would have cleared everything on the way in.
no matter though. Once i took the rear end down off the jack stands, I was able to slide both up in place from the bottom
junior04
09-28-2015 10:53 AM
