Somethings F***ed up!
1986 Mustang GT, doesn't run right. I have to adjust the timing to start, then move back. After it starts it idles nice until I shut it off, then I cant start it regurly again without messing with the timing. It seems like either a fuel or ignition problem. I am looking into ignitor coils being that its cold and they sometimes go bad. If its not the coil I think it might be the fuel pump or filter. It looks like something isnt getting enough of what it needs. Any ideas? Thanks guys
RE: Somethings F***ed up!
first things first....i'd set the timing back to factory spec and make sure the distributor has been installed correctly and follow the instructions on how to properly install it and time it up by removing spout connector to set base timing and then troubleshoot from there
I agree that it could be a timing problem. you can borrow a timing light from Autozone or Checker Auto if you don't want to spend the money on it. once you've checked the timing and it's not even close to any of the degree marks, go through the "Stab in Distributor" instructions listed in MF somewhere.
also like mjr46 said, you have to pull that spout connector out before adjusting timing or it just won't work.
Have fun.
Have fun.
ORIGINAL: loeryder21
I dont think its the timing, I set it last night with my timing light and everything is set to where it should be. Yes I took the spout out.
right, so far i have narrowed it down to either a spark issue or a fuel issue. The problem is that it idles so smoothly and doesnt miss so its hard to tell which it could be. The only apparent problem is that it wont start on its own will. I have to turn the distributer all the way to one side, then when it starts I move it back to the set spot. So to me, that says ignition coil or something to do with it
ORIGINAL: 93 LX FiveO
nope.. sounds like ur dizzy is the problem
if timing chain jumped the engine timing would be off.. it would not idle fine like he says it does and turning the dizzy wouldnt effect starting or not. the valvetrain and crank would just be not timed correctly.
