Stuck throttle body to intake suggestions?
This has prob happened to many, the 4 studs holding on the throttle body to the intake seem to be stuck on? I tried tapping with a rubber mallet and used a flat head screw driver to seperate to no luck? Any suggestions? Also, looking for a good supplier for replacement gaskets.
[align=left] [/align]
RE: Stuck throttle body to intake suggestions?
Where the iac bolts to the t/b, hit it on that lil flat area on the t/b. Or take a vey thin putty knife/gasket scraper and wedge it between the two pieces. Be careful though not to gouge the mating surfaces.
ORIGINAL: PRO50SC
im sure u did but ill say it anyway... drain some coolant before u take it apart.
go crazy with the hammer. ur stuff is brand new (or looks it)
i had to beat off my 14 year old tb with a wheel cover hammer (which is super light).. eventually it will move
