how much stronger is a mexican block?
RE: how much stronger is a mexican block?
I would think 500 would be pushing the limit to be honest but this is all hearsay to me. I have heard of that cracking at 500 and than at close to 600 so its a gamble imo.
this is in the tech articles
https://mustangforums.com/m_3022624/...tm.htm#3022624
the pictures are not working tho
Get them while you can.. my friend has one with the f1R on a mexican block pushing 27lbs of boost at 740 rwhp. if you don't want it i will. their like 1970 mustang racing blocks.
I personally don't have any experience with these, put I actually just read this in a five liter book while looking at something for my car.
It stated that the "mexican block" was made up until 1998, most were truck assemblies. They are 6-8 lbs heavier than U.S. manufactured blocks, and it said basically this is where the rumor started about them being stronger b/c Ford was retooling at their Cleveland plant, to produce "thin walled block castings." Where the mexican blocks where not retooled.
Stated they can be identified by a "hecho in mexico" cast in the lifter valley, and by casting numbers that start with designations such as C8AM-B and D1ZM-AA.
I know that the rumors got started during the original muscle car days about them being stronger, but this book argues against it. Regardless, it is a good conversation piece. Good Luck!
Because of they are thicker in the cylinder wall they could handle being bored.40 over. They were the cheap route to getting a better block; back in the day your only other alternative was an A4 block. Also, they are rumored to have more iron than a US block. As with any production block, you canmake 500+HP with it, but will it be reliable?
they are also supposed to have a higher nickel content, which makes them stronger than regular american cast iron blocks anyways. another identifier is two round **** thingys cast into the front of the block that american blocks dont have.
Matt's 95 Stang
10-05-2015 07:16 AM
