i want a cold air intake, any suggestions?
RE: i want a cold air intake, any suggestions?
make your own from some flexible aluminum ducting available at the hardware store.
why are you asking this question when the '87 already gets its air cold from outside the fenderwell anyway?????
Just go to the hardware or home improvement store and get some PVC pipe with elbows and a couple of those rubber connectors(not sure what they're called, I'm not a plumber), cut that stuff to the desired length, make connections, and viola.
My 5.0 is in a Lincoln Mark VII, and I will eventually do the same thing.
My Mustang is carbureted, and this is what it uses...
[IMG]local://upfiles/10806/709BDC70FFBE452E8C0F2F9C5DB74136.jpg[/IMG]
