Good cam for GT-40ps?
RE: Good cam for GT-40ps?
true #19 made with sn95 in mind:
Lift .480 w/1.6 rockers
Duration 220@0.050 intake
Duration 226@0.050 exhaust
Lobe Seperation 115 (the #18 was 112)
I like this comp cams offering ... its close to 5.0 stock cam with more lift, it is much more tame than several 50 state legal crowers This one has less duration than #19 at .050 and It desktop dynos to 409 hp with my 9.4:1cr 5.4" rod 302 with AFR 165 heads. I think it would work well on sn95
COMP Cams Magnum Hydraulic Roller Camshafts
CCA-35-310-8
Intake/Exhaust Duration at 050 inch Lift: 215 int./220 exh.
Advertised Duration: 270 int./276 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.533 int./0.544 exh. lift
Lobe Separation (degrees): 114
Here is my desktop dyno results comparing to the nearly equal crower cam. Its interesting..........
[IMG]local://upfiles/84695/7B39D8E5ABB04F2E987701F3266FCA85.gif[/IMG]
CCA-35-310-8
custom piece from camshaftinovations???
theres alot more to it then, what heads ur using... for ex. heads? intake? gears? compression? rockers? valves? intended use? emssions? and so on
ORIGINAL: XPBaller
Anybody else? Cam for gt-40ps for sn???
CCA-35-310-8
cam I orignally was going to use the GT40P heads with, it worked VERY well with the p heads on the simulation software. I used the GT40P head flow numbers from http://www.jason.fletcher.net/
I think it is an execellent choice, and you will get more power from it that the 19
Good luck.
ORIGINAL: dimebag
yea, i know id get more power with a custom cam, but this is something im trying to throw together cheap. got the heads for 150$ from the JY, going to find a used cam and some springs, and probably an explorer intake. I just want something with some pep while im building my other motor.
yes dimebag I do see your point...... HOWEVER[&:]
it is entierly possible you could get the comp cams mentioned here used, but a custom cam .......USED??
