turbo question
turbo question
i am going with a 427 stroked block and going to turbo it but wanted to know what is a good compression ratio running like 15-20psi and what intake and head could i put on the engine to make it still efi. also how would i run the oil supply and return lines lines.
RE: turbo question
for boosted applications, u want the compression low, like 8.5-1. heads dont matter much to keep efi as does the intake. for what u plan on i would run afr 205's and a box intake like the igloo or trickflow box. the victor 5.0 wouldnt be a bad choice either
RE: turbo question
no offense92gt50 but if you're really askin those kinda questions with those kinda ideas, i think you have a lot of research to do. thats an extremely expensive build and i dont think you want to just be askin guys what they think you should do. and for a turbo 427, i dont think that 205's will get close to cutting it if ur tryin to get the most outta it
RE: turbo question
ORIGINAL: greenstreak9205
If you're asking questions like that.. you obviously haven't done much to try and research things yourself. A turbo 427 is gonna set you back a LOT.
15-20psi >.< that's quite a bit of boost.
treesloth
09-28-2015 07:03 AM
