What to clean the heads with?
Old 03-07-2005, 08:03 PM
Moosetang
Moosetang's Avatar
Default What to clean the heads with?
I have my heads off and was wondering what I should use to get the carbon build up off them and get them ready for paint? I want to make sure it doesn't hurt my expensive heads. By the way their cast iron.
Moosetang is offline
Old 03-07-2005, 08:06 PM
bobby
bobby's Avatar
Default RE: What to clean the heads with?
what kinda heads?
bobby is offline
Old 03-07-2005, 08:09 PM
mustang8719
mustang8719's Avatar
I always use carb cleaner or brake cleaner.I have never had any problems with using those products.
mustang8719 is offline
Old 03-07-2005, 08:10 PM
83GT306
83GT306's Avatar
Hell, you could dip 'em in acid, and it would just ruin the rubber valve seals...?
Use some gunk engine cleaner, or take 'em down to the local pressure wash and water 'em good.
Brakleen works as well as carb cleaner.
You won't hurt the heads.[sm=smiley20.gif]
83GT306 is offline
Old 03-07-2005, 08:18 PM
Eric L. M.
Eric L. M.'s Avatar
i've found that oven cleaner works alot better than anything out there, and its not $5 a can. just dont use it on aluminum.
Eric L. M. is offline
Old 03-07-2005, 08:25 PM
bobby
bobby's Avatar
get purple power, and simple grean, smother the crap out of them , let it sit, was off, that'll get-R-done
bobby is offline
Old 03-07-2005, 09:05 PM
fats429
fats429's Avatar
e-z off oven cleaner is the best
I would use a soft wire brush bit in a drill or right angle grinder gets the cast ready for paint
fats429 is offline
Old 03-07-2005, 09:42 PM
stanglx2002
stanglx2002's Avatar
i would use carb or Tb cleaner
stanglx2002 is offline
Old 03-07-2005, 10:56 PM
birdman076
birdman076's Avatar
Oven cleaner is fine for aluminum as well, it just leaves the pore open much like bead blasting does. We used it all the time in the tranny shop to clean the cases.
birdman076 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
kevsgt
10-09-2015 10:12 PM
Dathan
10-05-2015 05:52 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: What to clean the heads with?
