NEED HELP WITH THERMOSTAT!!
RE: NEED HELP WITH THERMOSTAT!!
On the front of your lower intake manifold, there is an aluminum elbow bolted on with two bolts. This is knows as the thermostat housing. You must remove those two bolts and pull off the elbow to access the thermostat. You will then need to reinstall it with a new gasket.
ok thank i bought he gasket..nwo i have a nother problem..i feel liek an idiot but hey im savin soem dough..i just put a new drive belt on my car, its on right its just not tightening...i start the car and none of the pullies spin..whats the deal?
ORIGINAL: 5.0 85 GT
first i would double check that it is the right belt, then make sure your belt tensioner is working right, then chack the diagram to make sure it is on right
it has very little resistance..but i dont really get what u are talking about either..lol i just loosened the alt and the belt slid off i slipped th enew one on tightend the alt..and it was way loose...
