oil pressure - Page 2 - MustangForums.com
oil pressure
Old 11-26-2007, 01:22 AM
1990foxconvert
Default RE: oil pressure
u guys shure he dont have spun bearing. my oil pressure wont go past 38psi at 4 grand ant it knocks for about 1.5 seconds when i first start it up. its at 11 at idel
1990foxconvert is offline
Old 11-26-2007, 06:03 AM
FoxGT
FoxGT's Avatar
ORIGINAL: dimebag
is it a highflow oil pump?
either way go buy a mech guage... i trusted my stocker... and ended up w a siezed pump and two thrown rods... whole time guage read that i was fine as far as oil pressure goes
i now have a mechanical one going on the car... i just dont know where to mount it
EXACT same thing happened to me... My pump shaft twisted in half & the gauge didn't read any different until about 3-4 miles down the road. Then it started going up & down. I shut the car off imediately & had already spun 3 bearings. Needless to say I bought an aftermarket gauge before the engine went back in. Those stock oil psi gauges do NOT work for sh*t.
ORIGINAL: 1990foxconvert
Mine had 8psi at idle (400 rpm) & only climbed to about 35psi. Alot of 302's seem to have a low oil psi problem. My friends daily driver 5.0 has about 10psi at his 800 rpm idle & has had that psi for about a year & a half. No problems whatsoever. I replaced the bearings & had the crank reground. Never goes below 35psi now, even 35psi at 400 rpm.
From what I can tell alot of 302's have a low psi problem. Doesn't seem to effect them much.
You could try running a little thicker oil.
FoxGT is offline
Old 11-26-2007, 07:37 AM
1990svt5.0
i use castrol 20 w 50 high millage thats y i think it doesnt knock it doesnt matter the car will be sitting im my shop for the winter doing a rebuild so this just made me have to do it
1990svt5.0 is offline
Old 11-26-2007, 07:44 AM
1990svt5.0
and i also forgot i also beleave its a bearing bc its doing the same oil pressure would go down in pressure then wen i drive it builds then i get on it the pressure drops i beleave its a bearing
Old 11-26-2007, 10:28 AM
my77stang
my77stang's Avatar
a high pressure pump can cure these infamous low pressure situations, im running a high volume pump right now because i couldnt find the HP pump with the lower cover that supports the internal gears like i wanted, but i ended up with REALLY high pressure anyways. Im not sure if i pinched my oil pressure gauge hose when i tightened the fittings up or if it has anything to do with a tight #1 cam bearing, but going from 15w40 rotella to 10w30 pennz didnt drop it more than *maybe* a lb or two.
my77stang is offline
svfetter
10-05-2015 12:39 PM
88 orangepeel notch
10-05-2015 10:03 AM
wraith777
09-28-2015 11:49 AM
ccdguy
09-19-2015 06:20 PM
SteelerNation82
09-16-2015 08:11 AM
Quick Reply: oil pressure
Featured Sponsors
