electric fan retrofit
I've already tried the search function to no avail. I purchased a Hayden 16" heavy duty electric fan today from a local vendor, and also the fan control kit. The fan looks like it will fit inside the factory fan shroud which I want to retain. The fan is rated @ 1500 cfm. I'm wondering at this point if this is enough air volume. The car still has a functioning A/C system, and removal is not an option (too hot in South Carolina). I've seen other fans rated at 2000 & more cfm. What's everyones experience with this? I cannot find any cfm ratings for the stock mechanical fan. I do plan on incorporating this with an alternator upgrade as well. If 1500 is not enough, I can always take it back, and order something else.
RE: electric fan retrofit
ORIGINAL: CHILLERMAN
ORIGINAL: 5pnt0gt
i used a black magic with 2600 cfm and 3 core rad and car over heated with a/c on. 1500 is nowhere near enough.
ORIGINAL: 86 5.0L
take it back
http://www.fordmuscle.com/archives/2...cfan/index.php
flows OVER 3000cfm
take it back
flows OVER 3000cfm
Seanam
10-04-2015 10:15 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
