Wheel hop after susp mods ? ?
Guys, I am experiencing wheel hop on my 93 notchback 5spd 60k miles. I started out with no wheel hop stock. I have Kenny Brown subframes installed. When I put the Ford motorsport springs on all four corners no wheel hop. Then put on summit upper and lower control arms in combo with lakewood 50/50 drag shocks. After the fresh install I got a lot of wheel hop in this car for the first time. Being that the shocks were fresh and new I thought to give them some miles and break-in. The wheel hop did die off a little, so I tossed on the stock quad shocks and that helped a little more but the wheel hop is still there. Inoticed that the wheel hop is huge in colder temp if that is any help.
What do you think? I thought that all that susp modding would improve performance... but for me I am getting the one symptom that should by theory be non-existant. Thanks for your input.
RE: Wheel hop after susp mods ? ?
what kind of shocks are you running on the front?. if the front is not able to lift enough with the 50/50s on the rear you will experince some wheel hop. and the 50/50s are not really made for street use. put some 90/10s on the front and see what that does for ya. lower your rear tire pressure a couple lbs also.
ORIGINAL: 5pnt0gt
no wheel spin = no wheel hop
get a sticky tire and call it a day
but mega byte jr's have eliminated wheel hop in 5 of 5 cars i have put them on even w/ street tires
I have stock front struts. Also I did tighten the control arms with the weight of the car down. I have Firestone 50sz tires 245/50/16 which really are a hard tire. How about the struts in 70/30 ratio?
ORIGINAL: greenstreak9205
90/10's are great for the straights and all but it makes the front pretty floaty. so at least keep that in mind if you do wanna look into switching
the non-adjustable Summit brand uppers and lowers.
I have a feeling that the upper bushings on the rear axle ... where the upper c-arms mounts to are worn and will need to be replaced. That's probably the weak link here. If I go to do that I will upgrade the uppers to adjustable.
09-08-2015 11:50 AM
