Battery charging problems...
My girlfriends Explorer is having some battery problems. It died last night at my house and i hooked it up to the batt. charger right away. It was good the next morning, but the battery gauge still reads low. I was able to drive it back to her house, but the needle keeps creeping down. I checked the fuses and they are all good. I know it could obviously be the alternator, but it could be the battery too correct? I don't want to buy a new alternator only to find out that it was just the battery itself that was the problem. Oh and I posted this here because i know you guys better than anyone else, and the 5.0 section gets more traffic. Thanlks guys.
RE: Battery charging problems...
its the alt or the voltage reg but most likely has the voltage reg as part of the alt. so anyway you need a new alt. you should be able to drive and the gauge stay right where its supposed to be with a dead battery.
ok problem solved. Take it to autozone if you have one and have them test the battery under load etc and see if there is a dead cell in it or a problem with it and then have them test the alternator. Seems simple enough, good luck! Also, i wonder if they could benefit with the 3g alt and or if they would fit?? hmm....they probably already have them tho considering there later model cars.
i believe those already have it. its gunna be the alt im sure if he kept driving it it would have died i was able to drive around with no alt for a couple hours before the battery finally died was able to start the car like 4 5 times too
bradleyb
11-27-2015 07:50 PM
logan409
09-26-2015 07:43 PM
