Question??????
Old 03-08-2005, 12:14 PM
stanglx2002
Default Question??????
Beside putting on a EGR simulator cant you just put a block off plate between the EGR and the EGR spacer? if you do that will it mess witht he computer or not? i took off all my smog crap, so the EGR is the only part left on and i know it can mess up your idle bc it is dirty so if you put the plate between wont it keep the EGR clean and tell the computer its closed all the time?
stanglx2002 is offline
Old 03-08-2005, 12:34 PM
angcobra
Default RE: Question??????
Not sure about the plate you are looking for to go between them. I am removing the egr and spacer completely, I will deal with codes in chip programing. This plate in the picture is from Steeda and goes between the intake and TB in place of the spacer.
[IMG]local://upfiles/10436/9A5027B5CF1A45A59E12723708400B98.jpg[/IMG]
angcobra is offline
Old 03-08-2005, 12:59 PM
stanglx2002
im going to leave my spacer on. i just wanted to know if i can block off the EGR from the spacer with a plate between the 2
Old 03-08-2005, 02:06 PM
angcobra
First thing I did was remove the EGR valve and put a flat plate where the egr use to be. I made my own just cut it to length and then marked and drilled the two bolt holes.
angcobra is offline
Old 03-08-2005, 02:09 PM
stanglx2002
doesnt that messup the computer bc it isnt plugged up? thats why i was going to put a plate between the EGR and spacer but leave the EGR plugged up. i was thinking it was going to make the computer think the EGR is closed all the time.
Old 03-08-2005, 02:13 PM
angcobra
You may have the better solution for you. I am removing all emission stuff completely.
angcobra is offline
GimpyHSHS
03-12-2018 04:16 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Question??????
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
